Stax SR-009 najlepsze słuchawki, tak czy nie?
  • 3867 / 6824
21-04-2018, 15:31
Ja bym poszedl nawet dalej, mysle, ze wkrotce ktos ich kupi ;'))
wiktor
  • 2504 / 6824
  • Moderator Działu Słuchawki
24-04-2018, 16:34
Do dzisiaj miała to być tajemnica.
wiktor
  • 2504 / 6824
24-04-2018, 16:35
wiktor
  • 2504 / 6824
24-04-2018, 16:41
I jeszcze taki maluśki update.
wiktor
  • 2504 / 6824
24-04-2018, 16:41
STAX Japan introduce the SRM-D10, the world’s first compact DAC / electrostatic amp unit. High-performance DAC for PC / Mac and variety of digital audio sources, from the desktop part of the amplifier can be adapted STAX mainstream electrostatic earspeakers. Now you can take the SRM-D10 to your home, office, or out door and enjoy the superb sound from STAX anytime, and anywhere you go.
Portable amplifier for STAX electrostatic earspeaker with built-in Lithium Ion rechargeable battery pack.
Full Aluminium case with multiple processes to achieve velvet feeling.
XMOS USB interface supports DSD 5.6MHz signal playback and PCM audio with up to 384KHz sample rate.Astronautic level high voltage amplifier for perfect high frequency response and constant good performance.
Well-selected internal components reflect high quality requirement.
Standard STAX 5Pin connector for all STAX earspeakers.
 Wide range switching power supply provides flexible power handle capability.
Specification
●Frequency response:20Hz – 40KHz (+0dB,-3dB)
 ●Rated input level:230mV (100V output)
 ●Maximum input level:10V (minimum volume in analog input)
 ●Gain:53dB (450 times)
 ●Harmonic distortion:<0.025% / 1KHz-10KHz
 ●Input impedance:10 KΩ(analog input)
 ●Maximum output voltage: 200Vr.m.s / 100Hz-10KHz
 ●Bias voltage:DC 580V
 ●Supply voltage:DC 14V
 ●Battery Operating time:4.5hour(analog input) / 3.5hour(digital input)
 ●Power consumption:6.4W (USB input)、5W (analog input)
 ●Recommended operating temperature: 0-35°C, <90% RH (No condensation)
 ●Signal input:MicroUSB digital input, 3.5mm analog input
 ●Dimensions:140.8W × 32H × 75Dmm
 ●Net weight: 450g
  • 1954 / 6216
25-04-2018, 20:49
Nic tylko czekać na pierwsze rzetelne porównania do starszej wersji.
pmcomp
  • 227 / 5848
09-05-2018, 10:01
Może warto jeszcze pokazać z tyłu:
Jak dla mnie brak wejścia SPDIF dyskwalifikuje to urządzenie jako DAC. Cóż, świat się zmienia. Rządzą pliki a CD do lamusa.
Pozdro
« Ostatnia zmiana: 09-05-2018, 10:03 wysłana przez pmcomp »
pmcomp
nsk
  • 549 / 5794
09-05-2018, 10:36
CD-ek raczej mało przenośny jest więc dobra decyzja :).
pmcomp
  • 227 / 5848
09-05-2018, 10:45
A jak już jestesmy przy sprzecie przenosnym to warto też popatrzec na wzmak KingSound M-03:
Napędza zaróno elektrostaty Staxa jak i słuchawki dynamiczne.
Nie wiem ile kosztuje SRM-D10 ale KingSound kosztuje 449 EUR. Brak DACa ale napędza jak napisałem także dynamiki i do tego w bonusie potrafi robić za powerbank dając 5V na wyjściu USB.
http://kingsaudio.com.hk/000/m03.php
https://headfonics.com/2017/02/the-m-03-ks-h4-electrostatic-system-by-kingsound/
https://www.head-fi.org/threads/the-stax-thread-iii.677809/page-986
https://kingrudi0504.blogspot.com/2016/08/kingsound-m03-headphone-amp-stax-sr-007.html
« Ostatnia zmiana: 09-05-2018, 10:50 wysłana przez pmcomp »
pmcomp
nsk
  • 549 / 5794
09-05-2018, 10:57
No to jeszcze ciekawe jak gra :). Bo to, że coś jest bardzo funkcjonalne to nie napawa mnie optymizmem.
Alucard
  • 2762 / 4532
09-05-2018, 14:32
Na zagranicznych forach piszą że nowe Lambda 700 są najlepszymi aktualnie słuchawkami w ofercie Staxa. Dużo w tym prawdy, czy kwestia toru i upodobań?
pmcomp
  • 227 / 5848
09-05-2018, 15:11
Podlinkowałem. Więcej recenzji i opisów mozna wyszukać samemu. Ja zamierzam sprawdzić osobiście i chyba zamówie tego M-03. Tym bardziej, że kosztuje połowę ceny SRM-D10. Mi DAC nie potrzebny bo mam wbudowany w moje iBasso DX100 i DX50. Poza tym nie słyszałem o przenosnym cyfrowym transporcie. A przenosne DAPy maja wbudowane DACki. Więc dublowanie mija się z celem chyba, że ktoś chce to podłączać do notebooka.
pozdro
« Ostatnia zmiana: 09-05-2018, 15:15 wysłana przez pmcomp »
pmcomp
mirhon
  • 438 / 6712
09-05-2018, 20:42
Miałem 404, byłem generalnie zadowolony, ale brakowało mi w nich dynamiki. Grały tak jakoś bez impaktu.
Zmieniłem na 507. Poprawiła się dynamika, ale znikła ta magia staxowa - to takie granie 3D. 507 grały zbyt monitorowo tzn. beznamietnie i tak jakoś na twarz. Mam teraz 700 i nic mi nie dolega :-)
  • 3867 / 6824
09-05-2018, 21:21
Gdybym ja miał wybrać pomiędzy 009 i L700, zakładając ze kosztują tyle samo, wolałbym jednoznacznie niższy model bo gra dla mnie plastycznej i znacznie mniej wyczynowo(w negatywnym znaczeniu), 009 męczyly dość szybko a L700 można było słuchać pół dnia i do tego szerszego repertuaru bo są uniwersalniejsze.
mirhon
  • 438 / 6712
09-05-2018, 21:31
Mnie 009 też nie podeszły. Porównywałem na różnych wzmacniaczach staxa i wolałem 507 ...
