  • 6463 / 6753
10-02-2009, 12:46
Panowie przypadkowo natknalem sie na jeszcze jeden - nowy - wzmacniacz serbskiego Trafomatic.
Poszukalem recenzji i dowiedzialem sie od kilku osob, ze ten wzmak ma bardzo dobra synergie z GS1000.
Zwie sie Trafomatic Experience Head One -> http://www.trafomaticaudio.com/experience_head_one.php
Jestem bardzo ciekaw ile zazyczy sobie polski dystrybutor (wyslalem pytanie).
Dane techniczne ze strony producenta sa takie:
Tubes: 2x 6S45P , 1x EZ80(81)
Power supply: 230VAC (option 115VAC) , 50/60Hz - 50VA
Consumption: 30VA
Output impedance: 30 -100 – 300ohms
Maximum output power: 300mW
THD at 100mW/1kHz: 3 %
Additional outputs: line out i sub out
Inputs: CD , AUX
Input sensitivity: 1Veff
Input resistance: 47Kohm
Output line voltage:
THD 1% - 3.2V
THD 2% - 6.4V
THD 2.8% - 9V
Frequency bandwidth:
headphone and line out 20Hz(-3dB) – 57KHz(-3dB)
Subwoofer out 20Hz(-3db) – 18KHz(-3dB) S/N: 71dB
Minimum load resistance on “LINE and “SUB”:
- 2k ohm both outputs simultaneously;
- 1k ohm single output.
Gain on “LINE” output: 18dB
  • 6463 / 6753
10-02-2009, 12:48
Opinie sa np. takie:
GS1000?
At first it was not the best combination, but in the end they matched wonderfully. The forwardness of this amp is perfect for the midrange of the GS1000. Bass is full but controlled. Highs are clear and detailed, but never harsh.
HD650?
Is it as good as the Earmax Pro with the HD650? Yes. Not better though, but everything as good. Senns can rock like you wouldn\'t believe.....
I haven\'t used my balanced HD650 and my RPX-100 in quite a while any more.
If you like your music full bodied, and with lots of impact in every sense of the word: this is the perfect amp.
To get to my sound impressions I had to do some preliminary burn-in.
A LOT it turned out.
At first I was not over enthousiastic: too massive, boomy bass, a bit grainy, very forward, but I decided to give it some time.
Am I glad I did.
After 100 hours it was already a different amp: much better detail, better controled bass. Still very massive and forward though.
I was happy. Good amp.
Then I did some more burn-in and it got better and better.....
Differences were not night-and-day, but considerable:
More detail, especially in the midrange.
Much better control and detail in the bass.
More extension in the highs.
More clarity overall.
Main characteristics:
Forward: it packs a massive punch.
Powerfull: sound is full bodied and massive.
After about 500 hours it stopped changing, at least I didn\'t detect any change any more.
I mainly compared it with Corda Prehead and X-CAN v8 and used my computer as source (JOB 48 NOS DAC) and a couple of thousand different albums of all genres.
I also compared it with the Earmax Pro, but only for use with the HD650.
intuos
  • 1003 / 6783
10-02-2009, 13:04
"W każdym razie teoria, że słuchawki nabierają cech toru, z którym na co dzień współpracują, wydaje mi się dość zasadna, a przynajmniej tym przykładem raczej potwierdzona niż obalona."
Zgadzam sie w 100%.
  • 7477 / 6783
10-02-2009, 13:06
W takim razie niech Rolandsinger wyśle swoje K701 do któregoś z kolegów, żeby się zlampizowały brzmieniowo, i będzie OK. ;)
  • 6463 / 6753
10-02-2009, 13:16
Piotr:
Hmm, byc moze wlasnie tak jest i dopiero pokazna moc pozwala odpowiednio je wysterowac. Wydaje mi sie to logiczne biorac pod uwage doswiadczenie nas wszystkcih z tymi sluchawkami.
Gosc, ktory posiada ten wzmacniacz i GS1000 bardzo sobie chwali, no ale wiadomo - gusta sa bardzo rozne.
Idac ta droga, powinien to byc w takim razie Woo2 a nie Woo6 i nie Trafomatic.
Po redesignie zasilania i z lampami 5998 podobno Woo2 wedlug Jacka Woo jest jednym z mocniejszych ampow na rynku.
x500
  • 461 / 6762
10-02-2009, 13:49
Nie widze na stronie vivanco tych sr470 ... Moglby ktos dac fotke ?
chrees
  • 1662 / 6783
10-02-2009, 14:01
http://www.vivanco.de/cgi-bin/vivanco/en_US/teaserInfo3.html
  • 6463 / 6753
10-02-2009, 14:02
X500 - fotki sa kilka stron wczesniej.
Ja jeszcze mam pytanie odsnosnie Vivanco wlasnie.
Czy duzo wychodzi na zewnatrz, mysle nad nimi jako sluchawkami biurowymi ale nie chce tez przeszkadzac wspolpracownikom.
aasat
  • 2425 / 6766
10-02-2009, 14:05
>> fallow, 2009-02-10 14:02:30
Dokładnie tak samo pomyslałem, szukałem własnie sluchawek do pracy w stylu Sony MDR-F1 aby slyszec co sie mowi do mnie, zaryzykowalem wlasnie i zamowilem 2 szt od dystrybutora dla siebie i kumpla z pracy
x500
  • 461 / 6762
10-02-2009, 14:07
Dzieki Panowie . Sorki , nie zauwazylem ich na wczesniejszych stronach . Estetycznie to nie jest zadne halo niestety . Jedynie cena fajna . Na www.vivanco.com.pl ich nie ma skad wiec zamawialiscie ? Kupilbym sobie parke .
aasat
  • 2425 / 6766
10-02-2009, 14:12
>> x500, 2009-02-10 14:07:28
Na www.vivanco.com.pl ich nie ma, ale mozna napisac maila i zamowić, przesylka nieco droga bo kurierem
  • 7477 / 6783
10-02-2009, 14:15
Do Grado nie potrzeba mocy, raczej zapasu pojemności kondensatorów w zasilaczu, a również sprzęgających w przypadku OTLa, z racji niewielkiej impedancji słuchawek. Poniżej specyfikacja TH III, nie wiem czy to dotyczy akurat 32 omów, ale mocy w masakrycznej ilości on nie dostarcza. Ten Piotra na pewno ma ogromne kondensatory sprzęgające, i to basowi służy.
http://www.divertech.com/asltwinhead.html
  • 6463 / 6753
10-02-2009, 14:25
Hmm.. No to ja powiem tez tyle, ze mi nie brakowalo basu w GS1000 ani na RudiStorze ani na Yamamoto. Nie potrzebuje jego duzej ilosci - oczywiscie lubie solidna podstawe, ale wazniejsze jest dla mnie odpowiednie odwzorowanie w kontekscie ADSR, faktury i impakt niz duza ilosc.
GradoFanowi np. poziom ilosciowy basu z mojego DACa byl chyba troche za maly a dla mnie w sam raz.
Te kondy w Woo2 sa chyba rozmiarowo porownywalne lub troche wieksze od tych z Yamamoto.
  • 7477 / 6783
10-02-2009, 14:46
Woo daje z reguły 470uF na wyjściu, a to jest całkiem sporo, bo spadek napięcia -3dB wystąpi przy 11Hz. Ja nie mam tego problemu, bo mój wzmacniacz przenosi od 0Hz. :)
intuos
  • 1003 / 6783
10-02-2009, 14:52
na wyjsciu elektrolity....odrazu radze wymienic je na olejaki, inaczej zaatakuje nas zamulenie i brak mikroszczegolow.
