aasat
  • 2425 / 6782
22-01-2009, 00:00
>> pastwa, 2009-01-21 22:59:57
Nie ma zadnych przelaczników na tylnej sciance, ale teraz jak nie szumi to nie ma juz znaczenia
piter z
  • 375 / 6802
22-01-2009, 22:32
blue hawaii se w koncu ujrzal swiatlo dzienne
alghar
  • 639 / 6511
02-02-2009, 20:12
Panie Piotrze  ,można  recenzje   v8  majkel-a  ,  tą  dłuższa  :)
wiktor
  • 2503 / 6799
  • Moderator Działu Słuchawki
02-02-2009, 20:46
Na Ebay oferowane są ostatnie sztuki wzmacniacza dedykowanego do AKG K1000. Cena 498 Euro.
Opis:
We had decided a few weeks ago to stop the production of the K -1000.
However since the last 10 units in stock were sold within 1 week on ebay and further requests have been arriving,
an additional 30 amplifiers will be produced for delivery in February 2009.
K-1000 Now
The K-1000 Amplifier allows the connection of 2 sets of headphones on the front panel at the same time.
They run parallel and if you use only one set of headphones, either one of the sockets can be used.
The input sockets are located on the rear side of the device and, as is common with studio technical equipment, are implimented as XLR input sockets.
Should you not have the correct cable and connection possibilities, you can get an adapter at your local electronic accessories store.
With this adapter a normal asymetrical chinch cable kann be connected.
The switch "Line/Aux" switches between 2 different amplification levels.Which of the 2 you use is dependant on the output resistance of the source.
You can simply try out which setting utilises the volume control better.
The K-1000 amplifier is a very puristical device without a sound regulator, loudness switch or similar.
This construction was chosen in order to ensure that the input signal is amplified without loss of sound and tone quality.
It is constructed as a pure class A device and because of this it amplifies the music signal extremely distortion free.
Even when turned of , the device stays connected to the power network to ensure an optimal sound developement from the first minute on.
For this reason it is normal that the device remains warm.
The relocated power supply effectively prevents any buzzing or feedback sounds from the transformer.
The amplifier protects both your headsets and your ears from too high sound levels.If the volume remains too high over a longer period,
it is automatically turned off for 5 seconds.This is indicated by the LED on the front panel which will then blink.
Your headset is also protected from variation in the current voltage, which could otherwise potentially damage them.
The Amp will be delivered with SAC sign instead of AKG and with one plug in for AKG and one for varius headphones with 6,3 mm plug.
brzydkiosw
  • 1 / 6467
03-02-2009, 20:24
Cześć!
czemu nie dałeś zdjęcia flaków? - przecież ten "bajer" sam sobie zrobisz za tauzena PLN?
pzd
brzydki
  • 6463 / 6769
05-02-2009, 17:35
Tutaj sobie ktos zrobil niezla zabawke -> http://home.swbell.net/pabbi/MaxLives.jpg
krisio06
  • 347 / 6628
05-02-2009, 17:46
Zbalansowany Millet Max..:)
marcin555
  • 4 / 6458
12-02-2009, 22:41
Przymierzam się do zakupu słuchawek HD-650 i wzmacniacza Cayin HA-1A lub MF X-CAN v8.
Który wzmacniacz wybrać do w/w słuchawek?
Pytanie 2:
Gdzie można kupić nowy HA-1A i opisywane lampy NOS ?
Jaki jest koszt takich lamp?
Marcin
alghar
  • 639 / 6511
12-02-2009, 22:45
a  słuchałeś  innych  słuchawek ?
marcin555
  • 4 / 6458
12-02-2009, 22:55
Miałem kiedyś HD-600 i byłem z nich zadowolony.
Słuchawek Grado czy AKG nie testowałem.
Jakieś konkretnie polecasz ?
Marcin
  • 7477 / 6799
12-02-2009, 23:01
W HD650 to ja widzę kabel do wymiany na dzień dobry. Z fabrycznym te słuchawki są mniej ciekawe niż HD600, no chyba że ktoś lubi taki zabarwiony dźwięk przez całe pasmo. Zu Mobius MkII, do tego wzmacniacz lampowy, a za resztę budżetu sobie lampki wybierzesz.
marcin555
  • 4 / 6458
12-02-2009, 23:06
Czyli wymiana kabla na Zu Mobius MkII a wzmacniacz który polecasz ?
alghar
  • 639 / 6511
12-02-2009, 23:07
Zu Mobius MkII, :)  Michał  znajdz  jego  tańszy  zamiennik :)   a postawie whisky :)
  • 7477 / 6799
12-02-2009, 23:18
Mogę zrobić na Conducfil Sonolene 3014, tylko te konektory załatw. :))
alghar
  • 639 / 6511
12-02-2009, 23:25
a  wymiana  kabla   w  HD 600 ma  sens ?
