JBL EVEREST PROJECT DD66000 - DIY
atlon11
21-03-2014, 06:50
Widzisz firmowe pomiary DD66000 aż do 50kHz - które to spokojnie przekraczają. Tam jest wszystko podane czarno na białym bez żadnych sekretów - bo to nie garażowa firma aby robić sobie lipę, i każdy o tym wie.
Rosyjskie już widziałeś, prawie identyko jak oryginalne.
Jeszcze Angielskie laboratorium o którym możesz sobie poczytać w recenzji Paul\'a Messenger\'a z  HI-FI Choice:
http://www.jblsynthesis.com/downloads/products/prod_92_634480739469487570_Everest%20HFC%20Article%204%2010.pdf
...i co Lancaster, teraz łyso Tobie, bo u Paul\'a Messenger\'a odpowiedź częstotliwościowa w zakresie od 300Hz do 10kHz mieściła się w przedziale +/-1.5dB! Jedynie bas im podbiło, bo angole wcisnęli paki w pipidówę, i tyle:
The ultimate top end
\'\'The speakers were positioned with normal left/right separation and as far from the rear wall as possible without blocking the doorway. Although a little closer to the wall than might have been desirable, I doubt it was much of a compromise, and the weight and bulk rendered further exploration impossible.
   There was a bit too much bass when measured under our usual far-field, in-room averaged conditions, but around six decibels below 250Hz didn\'t seem too excessive. However, what was totally impressive was the remarkably flat and even tonal balance further up: the response from 300Hz all the way up to 10kHz was held within remarkably tight +/-1.5 decibel limits. The ultimate top end roll-off was mildly marred by a small 17kHz spike.
   Not unexpectedly, sensitivity is generous, especially below 300Hz, if not quite as high as the specified 96 decibels above 300Hz. Furthermore, it\'s achieved alongside a fairly easy amplifier load, which stays between six and eight ohms over most of the range, only falling below five ohms at ultrasonic frequencies. The pair match was very close indeed and the ports are tuned to a relatively low 28Hz, ensuring good response down to 20Hz (at 92 decibel sensitivity under our in-room conditions).\'\'
\'\'James B. Lansing\'\' = Lansing Manufacturing ~ Altec Lansing ~ JBL...\'\'Hear the Truth\'\'
atlon11
21-03-2014, 07:56
Co to za DIY Everest DD61400 :-)
Two 14\'\' woofer 1400Nd (from K2 S9500)
Compression driver 2451j
Horn DIY Everest 2 (from Guido prototype MDF)
http://www.audioheritage.org/vbulletin/showthread.php?34647-Everest-dd61400
...cóż za głośniki wynalazł i to Everesty bez driverów UHF.
Jak tak, to można zrobić jakiegoś Everesta DD60151, choćby dla Gustawa i wstawić jemu Vitavoxy;-)...na basie 2x 15\'\' AK 151 + jego ulubiony driver S2 no i wszystko górki/detali jemu wystarczy:-)
  • 20990 / 6786
21-03-2014, 09:20
atlon,
nie wiem jak inni, ale mnie po takich "rekomendacjach" jak twoje nie chciałoby się nawet pójść na odsłuch jakichkolwiek JBL
(a na AS baaaardzo mi się podobały)
momentami mam skojarzenia z wpisami miłośników kambodży na innym forum ...
"Po 2 godzinach sam niemal dałem się przekonać tym naukowcom, byli bardzo wiarygodni. Na szczęście mam inne poglądy". - prof. K. Kik
"To przekracza moją wyobraźnię". - S. Chandrasekhar, laureat Nobla, zwolennik teorii, wg. której cała materia Wszechświata miała swój początek w nieskończenie małym punkcie
atlon11
03-11-2014, 09:08
na dokładkę z niemieckiego Audio
« Ostatnia zmiana: 03-11-2014, 11:02 wysłana przez lancaster »
