Odtwarzacz cd Cary 308-T Doświadczenia posiadaczy
valhalla
  • 31 / 6638
31-01-2009, 18:25
Witam
Bardzo jestem ciekaw jakie są doświadczenia posiadaczy tego lampowego cacka.
valhalla
Road To Nowhere
  • 1043 / 6641
31-01-2009, 20:58
Czy to następca 306-stki ?
valhalla
  • 31 / 6638
31-01-2009, 22:04
Witam
Absolutnie.
cary 306 SACD chyba jest najnowszym wytworem firmy, natomiast Cary 308-T jest odtwarzaczem starszym. 2 lampy 12 AU7, filtr HDCD. Charakteryzuje się niesamowitym brzmieniem.
valhalla
valhalla
  • 31 / 6638
01-02-2009, 20:58
SPECIFICATIONS  Cary 308-T
Weight: 25 lbs.
Dimensions: 4" H x 18" W x 15" D
Transport: Philips CDM12
Frequency Response: 2 Hz - 48 kHz in 96 kHz upsample mode
Signal-to-Noise Ratio: >90 dB, A weighted
Total Harmonic Distortion (THD): 0.0009% (1 kHz)
Channel Separation: >100 dB (1 kHz)
Power Consumption: 35 Watts
Digital/Analog Converters (DAC): Burr Brown PCM1704u (24 bit 96 kHz)
Digital Filter: Normal 44.1 kHz, upsample 96 kHz or HDCD® decoding.
Audio Output section: Vacuum tube gain and buffer stage with dual 12AU7 vacuum tubes
Audio Output Level: Single-Ended 3.6 Vrms, Variable analog domain output level control, standard
Analog Outputs: (1) pair single-ended via RCA connectors
Digital Outputs: (1) Coaxial RCA output
Rated output voltage: 3.6 volts, with variable analog volume control
Power Input: 100-120/200-240 VAC, 50-60 Hz
CD 308-T CD Player / Transport
Tonality       90
Sub-bass (10 Hz - 60 Hz)        85
Mid-bass (80 Hz - 200 Hz)        90
Midrange (200 Hz - 3,000 Hz)        90
High-frequencies (3,000 Hz on up)        89
Attack        89
Decay        88
Inner Resolution        89
Soundscape width front        90
Soundscape width rear        87
Soundscape depth behind loudspeakers        90
Soundscape extension into the room        90
Imaging        92
Fit and Finish       90
Self Noise        100
Value for the Money       85
valhalla
