Kennerton VALI - słuchawki dynamiczne z Rosji za 1k$
  • 4439 / 6237
16-09-2016, 09:33
Słuchawki zaprojektowane i wykonane w Rosji.
Driver Unit 50 mm
Frequency Response 10-28000 Hz
Sensitivity 100 dB
Impedance 32 Ohm
Maximum Input Power 500 mW
"The Heart of Vali
Vali is equipped with unique 50mm drivers using ultra-lightweight paper composite diaphragms that are exclusively designed with award-winning manufacturer, Peerless® by Tymphany. They offer great sensitivity, while reducing unwanted resonance and distortion. Its audio performance is then carefully tuned by our Russian engineers to ensure that nothing falls below excellence.
The diaphragm is specially designed and made of a composite paper cone shielded in multi-layered laminated film. Composite paper has been well known and widely used in speaker manufacturing because of the following reasons which you can also expect from Kennerton’s Vali.
    Low mass: Increases the response time to an incoming signal, while minimising the decay time. The result is a rich and emotional sound.
    High internal damping: Minimum, almost zero additional resonances produced. The result is a smooth and vivid presentation.
    Excellent stiffness: Allows the cone to oscillate without bending. The result is a much reduced distortion.
The mulit-layered laminated film further reduces the distortion by allowing the cone to move easily in perfect piston motion."
Synthax
  • 2323 / 4907
16-09-2016, 10:55
Mają mi wysłać do recki za jakiś czas. Ale na razie pochłonięcie produkcją, z tego co mi napisali.
  • 4852 / 6293
16-09-2016, 11:07
Wyglądają bardzo ciekawie, jeżeli zagrają jak stare radzieckie lampy to będzie hit ;)
  • 4439 / 6237
16-09-2016, 12:42
Wyglądają jak słuchawki tylko do Rocka. Patrząc na ten wygląd jakoś nie mogę sobie wyobrazić jak grają np. Dodę ;-)
Gdzieś kiedyś poruszałem temat dlaczego nie ma (przynajmniej ja nie znam) papierowych driverów do słuchawek... a tu proszę, będą. Firma koszmarnie droga (patrz model ODIN za $2.5k$ plus cło i VAT).
PS. Synthax, czekamy na wrażenia.
