  • 4439 / 6320
14-01-2010, 00:21
Jak dobry/zły jest wzmak wbudowany w Benchmark DAC1/Benchmark DAC1 USB ??
Producent, któremu nigdy nie wolno wierzyć pisze tylko "HPA2™ - Benchmark’s signature high-current, 0-Ohm
headphone amplifier. The HPA2™ is the ultimate reference headphone amplifier. It will
deliver the full rated performance of the DAC1 to the headphones. The HPA2™ maintains
less than 0.0003% THD+N under a full load from two sets of headphones. The DAC1
HDR has two 1/4” headphone jacks on the front panel."
  • 4439 / 6320
14-01-2010, 10:25
  • 4439 / 6320
14-01-2010, 13:18
Może nei do końca wysokiej klasy ale właściciel Greace Design pisze o wbudowanym w m()@ wzmaku tak
""The PCM 1730\'s current output and this allow us to build our own transimpedance amp for current-to-voltage conversion," Michael Grace told me. (The usual, cheaper approach is to turn current to voltage via a voltage-feedback op-amp.) "The way current-to-voltage conversion is handled determines the characteristics of the sound," he continued. "Current-feedback amplifiers have a low-impedance current input and so don\'t have slew-rate limitation issues with instantaneous changes in the current coming into the amp. Voltage-feedback amplifiers, by contrast, constantly operate in a nonlinear way when they\'re used for current-to-voltage conversion. As a result, transimpedance amplifiers have a more open, harmonically rich and detailed sound.
"No single design concept accounts for the [m902\'s] sound," said Michael. "For instance, we don\'t like electrolytic capacitors, preferring polymer film capacitors anywhere possible in the signal path. The headphone amplifier itself is an Analog Devices DSL transimpedance driver capable of very high current output. It can drive a signal from a modem in your home or office, via a twisted pair of wire, a mile or two to the phone company, and can deal with high amounts of capacitance and reactance. Because it has no slew-rate limitations, it can track the rich harmonic content and overtones of the music in a way that a regular amplifier can\'t." "
Nie do końca łapię ten techniczny język niestety ;(
  • 3857 / 6771
14-01-2010, 15:59
Jak ktos zainteresowany to mam informacje od sprzedawcy w UK, ktory dysponuje jeszcze 3 nowymi wzmacniaczami MF model X CAN 8, czyli ta wczesniejsza bez \'P\' (co stoi za funkcje preamp, jak sadze, dodatkowo nie ma DAC-a na pokladzie) w cenie 250 funtow, oryginalnie bylo 400 (choc dawalo sie znalezc i za 350, jak mnie pamiec nie myli). Nie mowie ze warto i ze to dobry wzmacniacz, a jedynie przedstawiam taka mozliwosc, sam beda mial do posluchania ten model za jakies 2 tygodnie, wiec sie podziele wrazeniami jak cos.
aasat
  • 2423 / 6754
16-01-2010, 11:11
Pisze w specyfikacji Coriolan\'a
Vacuum Tubes:  2 *12AX7 4*6SN7 2*5U4
  • 4439 / 6320
16-01-2010, 12:08
Czy ktoś z was miał do czynienia z http://www.opera-consonance.com/products/cyber20.htm
KeripDarnok
  • 5 / 6100
16-01-2010, 13:27
Słuchałem tego wzmacniacza w audiofilu w warszawie. Podłączone były do niego Sony MDR SA5000 i jakieś znajdujące się w sklepie Bayerdynamiki profesjonalne ale nie pamiętam dokładnej nazwy (miały okrągłe muszle i niski nr ale nic więcej nie pamiętam). Podłączony był do DACa AudioNote . Niestety odsłuch był 3 miesiące temu i nie jestem w stanie wszystkiego sobie przypomnieć. Możliwe że to z powodu przeciętności dźwięku. Przestrzeń nie wychodziła poza obrys głowy co przy typie prezentacji Sony powodowało szybkie zmęczenie. Nie pomagało nawet delikatne ocieplenie całości. Bass był całkiem dobrze kontrolowany, tworzył dobrą podstawę pod resztę jednak średnica i wysokie tony nie były w stanie tego wykorzystać. Czasem nawet noga zaczynała tupać :) Stosunek ceny do jakości w Polsce jest bardzo zły - w cenie ponad 2000 zł można dostać dużo lepsze konstrukcje. Za granicą wzmacniacz jest oferowany za znacznie mniejsze pieniądze (300-400$).
  • 4439 / 6320
16-01-2010, 13:58
>> KeripDarnok, 2010-01-16 13:27:58
RP około 699$ zatem 2.000 PLN to świetna cena za nowego.
szwagiero
  • 2240 / 6773
16-01-2010, 16:26
>> asmagus, 2010-01-14 00:21:09
Było już na ten temat na tym forum albo/i na AS... jednym słowem - dramat! Odpuść sobie jeśli chcesz używać go nie tylko jako DAC. Sądzę z pamięci, że wyższy poziom prezentuje podstawowy Holdegron.
Pozdrawiam,
aasat
  • 2423 / 6754
19-01-2010, 21:49
Bardzo nieładnie, Rudistor wyrzucił stronę z NX-33 nawet z archiwum. nie rozumiem takiego podejścia, teraz nikt nie może sprawdzić nawet specyfikacji.
  • 5033 / 6768
19-01-2010, 21:58
Pewnie mają mało audiofilskiego miejsca na serwerze ;)
  • 4439 / 6320
21-01-2010, 14:14
Czy ktoś może wie jak zrealizowane wyjście słuchawkowe ma ONKYO INTEGRA 9711 ?
Dawid-SS
  • 325 / 6363
22-01-2010, 13:31
Pewnie tak jak wiekszość wzmacniaczy domowych po przez dołączenie rezystora do wyjscia na głośniki :) Najtańszy najlepszy sposób bez dużej utraty jakosci, można te rezystorki zmienić na jakieś lepszej klasy, może to polepszyc dziebko brzmienie.
Piotrze, ale te Grado na półeczce niżej FEE, czemu nie dostały jakiegoś ładnego kabla z oplotem i ładnym wtykiem ?? :)
  • 2076 / 6702
22-01-2010, 14:03
>> asmagus
Mam serwisówkę tego Onkyo- podaj na PW maila to Ci wyślę.
Będziesz miał dużo szukania :)
  • 4439 / 6320
29-01-2010, 17:18
Może to głupie pytanie, ale w necie znajduje rózne opinie, rozbieżne.
Gdy wzmacniacz ma przełącznik GAIN LOW/HIGH to pozycja LOW jest w zamyśle przeznaczona dla słuchawek wysokoefektywnych czy niskoomowych?
