NOS z urodzenia
  • 11712 / 6471
17-04-2014, 21:51
Poprosiłbym o listę typów odtwarzaczy bez oversyfilisu!
  • 11712 / 6471
28-04-2014, 17:50
Podobno Denon 1000 jest nosem na PCM53.Grundig 8100 na TDA1541,8150 na TDA1543.Jak wiecie co jest na pewno nosowe to dejcie mesydż!
Ludwik Igielski
  • 59 / 6297
28-04-2014, 20:33
Sorry za lekki bałagan, ale wklejam zawartość pliku txt
The short list of  CD players which have TDA1541A chip.
ACOUSTIC RESEARCH CD-06SE    TDA1541A    CDM-4
ADCOM GCD-575      TDA1541A    KSS-212B
ARCAM ALPHA          TDA1541A
ARCAM ALPHA 5 PLUS   TDA1541A    CDM-9
ARCAM ALPHA PLUS     TDA1541A
ARCAM DELTA   70.2   TDA1541-S1 (Single Crown)  CDM-4/11 / CDM-4/31
ARCAM DELTA BOX 1    TDA1541A
Bang & Olufsen Beogram CDX2   TDA1541A – SAA7220 CDM-2
Bang & Olufsen CD5500   TDA1541A   CDM-4/11
CAMBRIDGE AUDIO CD2   4 x TDA1541 – SAA7220   CDM-2/10
Cambridge Audio CD3 (4 x TDA1541 and CDM1 MKII)
CREEK CD60   TDA1541A-S1 – SAA7220P/B   CDM-4/14
GRUNDIG CD9009   2xTDA1541A/S1   CDM1mkII
LUXMAN D-500X’s II   TDA1541A-S1 (Single Crown)   CDM-3
MARANTZ CD-12   TDA1541A-S2 (Double Crown)  CDM-1
MARANTZ CD7   TDA1541AS2 (double crown)   CDM 12.3
MARANTZ CD80   TDA1541A/S1/Q   CDM1mkII
MARANTZ CD-85   TDA1541A-S1 (Single Crown)   CDM-1 Mk II
MARANTZ CD880J   TDA1541A-S1 (Single Crown)   CDM-1 Mk II
MARANTZ CD94   TDA1541A   CDM1
MARANTZ CD94mkII TDA1541A/S1   CDM1
MARANTZ CD-99SE   2 x TDA1541A-S1 (Single Crown)   CDM-1
MARANTZ CDA 94   TDA1541A-S1 (Single Crown)   It’s a DAC
Marantz KI CD10, 11, 16.
Non KI don\'t count... they are TDA1547
MARANTZ PROJECT D-1   2 x TDA1541A-S2 (Double Crown)   It’s a DAC
Meridian 206 mkII
MCINTOSH  MCD7005   TDA1541A   CDM-2/10
MCINTOSH  MCD7007   TDA1541A-S1 (Single Crown)   CDM-1
MERIDIAN 206   TDA1541
MERIDIAN 207   TDA1541A-S2 (Double Crown)   CDM-1 / CDM-4
NAIM AUDIO CD1   TDA1541   CDM-2
NAIM AUDIO CD2   TDA1541A   CDM-9
NAIM AUDIO CD3   TDA1541A-S1 (Single Crown)   CDM-9
NAIM AUDIO CDI   TDA1541A-S1 (Single Crown)   CDM-4/27 / CDM-9 Pro
NAIM AUDIO CDS1   TDA1541-S1 (Single Crown)   CDM-4/25
NAKAMICHI CDP-2E        TDA1541A – CXD1088
NEC CD-10   2 x TDA1541A-S1 (Single Crown)   KSS-150A
NEC CD-816   2 x TDA1541A-S1 (Single Crown)   KSS-150A
NEC CD-830DS        2 x TDA1541A-S1 (Single Crown)
ORELLE CD100SE   TDA1541A-S1 (Single Crown)   CDM-4
PHILIPS CD350 Mk II   TDA1541-S1   CDM-2/10 / CDM-2/29
PHILIPS CD-80   TDA1541A-S1 (Single Crown)   CDM-1 Mk II
PHILIPS CD-85   TDA1541A-S1 (Single Crown)   CDM-1 Mk II
PHILIPS CD-880   TDA1541A/S1/Q   CDM 1mkII
PHILIPS LHH1000   TDA1541A-S1 (Double Crown)   CDM-1
PIONEER PD-8070     TDA1541
QUAD 66     TDA1541A   CDM-9
ROTEL RCD-820   TDA1541
ROTEL RCD-855   TDA1541A-S1   CDM-4/19
ROTEL RCD-955   TDA1541   CDM-4
ROTEL RCD-955AX   TDA1541A – SAA7220P/B   CDM-4
SONY CDP-207ESD   1 x TDA1541 – CXD1088   KSS-150A
SONY CDP-301V   TDA1541 – CXD1088   KSS-210A
SONY CDP-333ESD   1 x TDA1541 – CXD1088   Sony BU-1E
SONY CDP-337ESD   2 x TDA1541A – CXD1144   KSS-190A
SONY CDP-507ESD   2 x TDA1541 – CXD1144   KSS-151A / KSS-190A
SONY CDP-555ESD   1 x TDA1541A – CXD1088   Sony BU-1E
SONY CDP-605ESD   TDA1541 – CXD1088   Sony BU-1E
SONY CDP-68   TDA1541 – CXD1088   KSS-210
SONY CDP-910   TDA1541A – CXD1088   KSS-151A
SONY CDP-M75   TDA1541 – CXD1088   KSS-210A
SONY CDP-M95   TDA1541 – CXD1088   KSS-210A
SONY DAS-R1   TDA1541AS1 (single crown)
SONY DAS-R1   2 x TDA1541A-S1 – CXD1144   It’s a DAC
STUDER  A727   TDA1541A-S1 (Single Crown)   CDM-1
STUDER  A730   TDA1541A-S1 (Double Crown)   CDM-3
SUDGEN SDT-1   TDA1541AS1 (single crown)
SUGDEN MASTERCLASS   TDA1541A-S-Crown – SAA7220   CDM 12.1
TEAC CD-Z5000   2 x TDA1541A   KSS-210A
TEAC D-500   2 x TDA1541A-S1 – SM5813   It’s a DAC
List of CD players with TDA1549
ALCHEMIST NEXUS APD32A  2 x TDA1549   CDM 12.1
MARANTZ CD-48           TDA1549       CDM 12.1
MARANTZ CD5000  TDA1549 - SAA7378     CDM 12.1 (VAM 1201)
MICROMEGA MINIUM   TDA1549            CDM 12.2
PHILIPS CD750   TDA1541A / TDA1549    CDM 12.1
PHILIPS CD751   TDA1549 – SAA7378     CDM 12.1/05
PHILIPS CD753   TDA1549 – SAA7378     CDM 12.1 / VAM 1201
SUGDEN MASTER   TDA1549               CDM 12.1
  • 11712 / 6471
29-04-2014, 10:08
Panie Ludwiku,to samo,ale o nosach plisss!
  • 11712 / 6471
29-04-2014, 16:07
Ale nie DACe,tylko playery.
  • 2076 / 6747
30-04-2014, 08:49
>> almagra
Przejrzyj wpisy kolegi gregaudio w zakładce "Klub Miłosników Starych Grundigów" na sąsiednim forum.
  • 11712 / 6471
30-04-2014, 09:30
Czytałem.
  • 11712 / 6471
12-05-2014, 18:07
Prawdopodobnie nosem na dacu CX20017 jest Loewe CD 180,którego też szczęśliwie zanabyłem.
  • 11712 / 6471
12-05-2014, 18:21
Ponieważ po rozkręceniu pudełka okazało się,że układem poprzedzajacym dac jest CX23035,który występuje również w Denonie dcd 1000,który jest na pewno nosem!Z tą różnicą,że Demonek jest na dacu PCM53.
  • 11712 / 6471
20-05-2014, 11:32
AKAI CD-M839 zawiera procesor cyfrowy M50421P,który nie ma filtru cyfrowego,bo małby dwie literki na końcu:P jak processor i F jak filter.Tak ma procesor w Philipsie CD614,który się zowie M50423FP.W związku z czem jest ten Akai urodzonym NOSem,co bardzo dobrze słychać,widać i czuć!
  • 11712 / 6471
30-07-2014, 12:55
Tak,każden jeden staren któren ma nic pomiędzy CX 23035,a dacem jest NOSEM.Tako rzecze almagra.
  • 11712 / 6471
30-07-2014, 12:57
Nosy,często mają też,ale nie muszą,filtry kubkowe LC w torze analogowym.
  • 11712 / 6471
30-07-2014, 13:02
A jak ktoś NOSA nie spotkał,to nic nie wie o cd.
30-07-2014, 13:10
wazne zeby uszy byly powyzej ;-)
