Audio Nirvana, Heaven i Raj utracony :-)
27-12-2010, 15:29
http://www.oswaldsmillaudio.com/about.html
"Audio. Today.
I think you can talk about two ways of pursuing audio today. One way is the mainstream of magazines and their online variants. This way is more about simply buying things than it is about sound. We all know that people today like buying things, and with audio, you are given a continuous excuse to buy new things (it's called upgrading) by the magazines and webzines whose very premise is to market an unending, monthly stream of continuously improving components, each one replacing and surpassing the next. One problem with this approach, which you can confirm yourself by visiting high end audio boutiques, or even better, visiting shows like CES in Las Vegas, is that even after spending $100,000 or more (easy to do) you are still in all likelihood going to end up with an unlistenable mess. You won't be able to figure out why. You bought the A list components, but it turns out sound is more than the sum of these parts. You will now be on an endless chase down the rabbit hole, looking for exotic cables, capacitor upgrades and cryogenic treatment of power cords, outlets and even circuit breakers (not kidding here, though I wish I was) to fix the "problem." The problem, of course, was that you actually believed that the magazines were giving you honest, well informed advice, not marketing the wares of their advertisers. Eventually you will either give up, convincing yourself you like what you have (it is, after all, rated A, B, C or whatever), or you enter neurosis.
The other way is entirely different. You will have to go Underground. The people who pursue the best possible sound have nothing to do with the way I describe above. They either build their own tube amplification, or they find or restore the best tube amplifiers of the past. The people on this path use highly efficient loudspeakers, usually in horns or as fullrange drivers, and these speakers are almost always vintage. The reason is simple- almost all speakers made today are awful. They have been designed for decades for a world of (cheap) solid state, high power amplification. If you were to tear open the most expensive speakers made today, Focal Grand Utopia, Wilson, etc, you would have nothing more than a pile of drivers which cost a few hundred dollars each, or even much less. If you look at the prices from the 1930's for professional RCA speakers in the RCA Museum and Archive section, you will realize just how expensive it was to make the loudspeakers of the past. Those speakers had to be very efficient, using field coil or Alnico permanent magnets, but because the tube amplifiers of that time had very limited power capacities, the voice coil gaps and dimensions generally were very close tolerances. Today's high efficiency pro sound drivers are made for running with high powered solid state amps, and their designs are compromised to ensure the drivers don't blow up when hit with great amounts of power. Loudspeakers can be likened to musical instruments. You cannot get a violin to put out the acoustic power of an electric guitar. This does not mean, by the way, that such vintage speakers cannot be played to more than adequate volumes for home listening. Many of these speakers were used in cinemas and stadiums- just not with cheap, multi thousand watt solid state amplifiers.
So, what does this all mean?"
rochu
  • 332 / 6793
27-12-2010, 21:00
Stereo underground.
Wieki temu pisałem o tym na AS.
NE5532
  • 206 / 6776
27-12-2010, 21:14
No cóż, nic dodać, nic ująć. Tak wygląda ta branża i nie tylko ta. W większości rynków hobbystycznych występuje taki właśnie podział. Z jednej strony mamy mainstream czyli kolorowe gazety, "wyścig zbrojeń" napędzający wyłącznie zyski kartelu "handlowo-prasowego", w efekcie prowadzący do głębokiej frustracji klientów wynikającej z braku realnej możliwości osiągnięcia celu, gdyż nie jest on w ogóle zdefiniowany. Liczy się tylko nowość, blichtr i cena - im wyższa tym lepiej. Z drugiej mamy natomiast całkowitą niszę, w której jest miejsce na kreatywność hobbystów i zupełny brak presji ze strony rynku (czytaj kartelu). Co więcej nisza ta nie stanowi żadnego zagrożenia dla rynku. Większość ludzi i tak kupi to co nowe i modne.
Bardzo dobry tekst ale trochę mało realistyczny w polskich realiach, a zwłaszcza jeśli chodzi o wysokoskuteczne głośniki typu vintage. Nawet na zachodzie czy w Japonii ich dostępność jest ograniczona, nie mówiąc o cenach. Mimo wszystko gorąco popieram.
Nie mam czasu ... zarobiony jestem, włosy mi rosną ...
  • 7477 / 6823
27-12-2010, 22:56
Między innymi dlatego, że zabawa w audiofilię nie zawsze wynika z wrażliwości na muzykę i wyczulonego słuchu. Często spełnia rolę szpanerskiego fetyszu w kręgach majętnych osób, a satysfakcję z brzmienia i tak mają - wmówioną przez sprzedawcę sprzętu.
rochu
  • 332 / 6793
27-12-2010, 23:43
Skoro o pieniądzach mowa.
Ścieżka proponowana przez pana Milla także do tanich nie należy, a kto wie czy nie jest ona droższa aniżeli standardowa zabawa w audio.
Ekstremalne vintage może być bardzo drogie (koszt zakupu i ewentualnej renowacji).
Firmy kojarzone z undergroundem w audio tez raczej do budżetowych nie należą (Shindo, Verdier, Auditorium 23).
Imacman
  • 102 / 6492
28-12-2010, 08:49
Za takie pieniądze to można kupić sobie dożywotni karnet do filharmonii, oraz bilety na wszelkie imprezy muzyczne w kraju do końca życia :)
Pozdrawiam. Marek
Yotomeczek
28-12-2010, 08:53
No można - ale paru nieżyjących artystów wtedy pomijamy...
  • 20990 / 6826
28-12-2010, 09:47
>> rochu, 2010-12-27 23:43:08
wystarczy ok. 10 kPLN
żeby wyleczyć się z neurozy
a nawet jeśli ktos chce wydać więcej
to nadal jest to jednorazowy wydatek
zamiast ciągłego karmienia potwora
28-12-2010, 10:46
proponuję rozszerzyć ścieżkę:
samochody - DIY
buty - DIY
chleb - DIY
Yotomeczek
28-12-2010, 11:15
>> Jarek
Chyba popadasz w skrajności...
rochu
  • 332 / 6793
28-12-2010, 16:19
>> magus, 2010-12-28 09:47:24
Wiem, że wystarczy.
Nie mniej ja pisałem o ekstremum.
  • 20990 / 6826
28-12-2010, 17:37
rochu
ekstremistom nigdy nie dogodzisz :)
tak sobie teoretyzuję, że gdyby wszyscy goniący króliczka wiedziało, jak owe 10 tys. zł wydać
to 90% przemysłu audiofilskiego zeszłoby z głodu
do czego dopuścić niemożna i stąd biorą się całe zastępy wujków dobra rada
rochu
  • 332 / 6793
28-12-2010, 19:38
Ale ja jestem ekstremistą ; )
I kiedyś będę miał dziesięciometrowe tuby w swoim domu.
  • 20990 / 6826
28-12-2010, 19:57
i tego ci, Rochu, życzę
z okazji i bez
Yogi
  • 493 / 6826
28-12-2010, 21:56
Rochu, będę pierwszy ;)
tuuuubyyyy
