1/2 falowe, 1/4 falowe, linie transmisyjne itd..
cypher
  • 252 / 6794
29-04-2008, 20:59
Jak w temacie TQWT/TQWP/BiB projekty, doświadczenia..
Zapraszam do dyskusji
Wklejania zdęć..
Na początek miły projekcik na:
Bass-midrange driver: Scan-Speak 18W/8542-05 ; 170 mm paper cone
Tweeter driver: Vifa D27TG-35-06 ; 25 mm dome (called HT-275D2 in NL)
L1 = 2,2 mH air coil
L2 = 0,39 mH air coil
C1 = 8,2 uF bipolar capacitor
C2 = 8,2 uF bipolar capacitor
C3 = 8,2 uF capacitor MKP
R1 = 5,6 Ohm/ 5 watt resistor
R2 = 2,7 Ohm/ 5 watt resistor
Technical details
Principle: Terminated line
Impedance: 6 Ohm
Sensivity: 88 dB (2,83 V/ 1 m)
Speaker drivers
Cabinet
All cabinet parts in 22 mm MDF, and the pieces listed below are for one speaker. Drawings of the cabinets Fig. 1. Drawings of the cabinets.
Front - back : 2 pieces 1000 x 210 mm
Side panels : 2 pieces 1000 x 256 mm
Top panel : 1 piece 166 x 256 mm (with a hole for the line exit)
Internal divider : 1 piece 775 x 166 mm (inclusive a 5 degree angle)
Bottom panels : 1 piece 272 x 166 mm (inclusive a 20 degree angle). 1 piece 138 x 166 mm (inclusive a 20 degree angle)
Damping materials:
Pritex 200 x 166 mm (under the top panel)
Pritex 450 x 166 mm (on the internal divider)
BAF 400 x 166 mm (bottom of the cabinet)
A picture showing placement of the damping materials Fig. 2. Placement of the damping materials.
Crossover
The crossover frequency is 2200 Hz. The filter is 12 dB/Okt Fig. 3. Crossover schematic.
Źródło:
http://www.speakerbuilding.com/diy/
cypher
  • 252 / 6794
29-04-2008, 21:02
marko3T
  • 421 / 6822
30-04-2008, 10:26
Ten projekt na Scanie , to  jest raczej połączenie BR z TL. Zbyt mały jest powierzchnia wylotu w stosunku do sd głośnika.
____________________________
Dobrze słyszę??  Tak , to bassreflex!
__________________
Tylko V2!
misiomor
  • 2094 / 6821
30-04-2008, 11:12
Racja, 0.5dm2 wylot to nie za duzo jak na TL, choć sporawo jak na BR do 18cm midwoofera. Poza tym midwoofer jest w jakiejś dziwnej wersji robionej na zamówienie.
cypher
  • 252 / 6794
30-04-2008, 11:18
Trudno mi polemizować w tym temacie twórca projetu określił to jako:
Terminated line
cypher
  • 252 / 6794
30-04-2008, 11:20
It uses a 7"Scan-Speak 8542-05 driver and a Vifa Tweeter the D27TG-35-06, in Holland also known as the HT 275D/2 (we use different numbers!). The cabinet is made according to a principle called a terminated line. I know that this is a kind of strange principle to use for such a driver but I had to come up with a reasonable amount of bass (design goal). I have also build this speaker in a bass-reflex box with a net volume of approx. 16 liters. This speaker sounded very analytical in the low freqencies but not as nice as the terminated line, it lacked a bit of natural warmth.
The terminated line which i called Transient II, has a much warmer and still very analytical bass performance. The mid is up-front but it also gives, together with the high, a lot of spaciousness. Transient performance is good. The tweeter gives a little too much at the end of the spectrum which gives the system, when used with certain electronics, a bit of bright, \'harsh\' sound.
cypher
  • 252 / 6794
30-04-2008, 11:23
8542-05 is a 7" with paper cone. Variants of it is used in the british ProAc Studio 100 and 200 series, and in the danish Avance Alpha. It has a very smooth frequency response to 2000 hz, but then some heavy cone resonances, with a ugly peak at around 5000 hz.
a_men
  • 746 / 6816
  • 4401 / 6821
04-05-2008, 12:14
Jak będę miał dostęp do skanera to wrzucę artykuł z Elektora Elektronika 1/1998 o stożkowej rurze Voigta VTP.
  • 4401 / 6821
01-05-2010, 21:36
  • 4401 / 6821
01-05-2010, 21:37
01-05-2010, 23:40
Bardzo interesujące i proste. Czy można gdzieś przeczytać na temat założeń VTP? Chodzi o to jakie parametry VTP przyjmować dla różnych głosników, jaką długość i pole powierzchni wylotu stosować. Jakie parametry powinien mieć głośnik do optymalnej pracy w VTP?
02-05-2010, 10:01
Coś podobnego, połaczone z bass-reflex\'em. Przebieg impedancji bardziej jak w obudowie compakt.
http://www.lautsprechershop.de/deutsch/index_hifi.htm
03-05-2010, 10:29
Co sądzicie o pomyśle wykonania TL na zasadach VTP?
Chodzi o to żeby wykorzystać pomysł z ustawieniem głośników w 1/3 długości rury, ale zastosować rurę zwężająca się ku wylotowi zamiast rozszerzającej się. Czy takie ustawienie głośników pomogłoby w zwalczaniu rezonansów pasożytniczych rury?
krisabc
  • 9 / 6792
24-06-2010, 00:04
ciekawa strona o TQWP po rosyjsku (z arkuszem Exela do samodzielnych obliczeń)
