  • 4439 / 6372
03-06-2011, 13:39
>> Detektyw Kwass, 2011-06-03 12:51:31
Troels Gravesen wykazał, że takie wygrzewanie daje wymierny efekt pomiarowy.
"It\'s always interesting to see how your TS data measurements correlate with the factory data. The "40Hz/4h" means second measurements after the drivers had been given some heavy 40Hz massage for 4 hours. (Several weeks of use didn\'t change this figure one single Hz).
Surprisingly the Qms and Qe are in good harmony, but the Fs and Vas.... Actually I don\'t mind the significantly lower Vas and higher Fs as we can use a smaller cabinet. That\'s something. I really wonder if the suspension will soften so much it will reduce the Fs by 10 Hz. And subsequently raise the Vas to almost twice the current value. The TS data were done by the added volume method, using a 29.4 litre closed enclosure to measure the increase in Fs.
The 4 hour data were inserted into the LspCAD box function and the usual range of box volumes and vent tunings for SBB4, QB3 and SC4 can be viewed and some 34-36 litres volume is calculated and with the SBB4 alignment a 30.5 Hz vent tuning is suggested with a -3 dB point of 45 Hz is achieved. A little higher than anticipated. From practical experience, driver with a Qt between 0.3 and 0.4 performs the best in accordance with all the nice math. And I would even narrow this down to Qt = 0.33 - 0.38. Drivers with a Qt = 0.25 or Qt = 0.50 really do not fit in."
http://www.troelsgravesen.dk/PMS.htm#Poor%20Man%27s%20Strad
Mozna też spróbować wygrzewać w inny sposób, tak jak wygrzewa się głośniki z innych krajach:
http://www.autohificlub.cz/forumimages/2006_10_17_11_11_082811.jpg
Max
  • 2204 / 6320
03-06-2011, 16:52
>> Vinyloid, 2011-06-01 14:35:01
>> Max, 2011-06-01 13:02:23
Czy ktos juz przerobil ATH-W1000X ? Jakies doswiadczenia z poprzednikiem - W1000 ?
Krótko ale wrażenia mam b. pozytywne. Podobały mi się zdecydowanie bardziej od W1000 i W5000. Barwę mają jaśniejszą i przez to dość podobną do D7000, niemniej ze wzgl. na lepszy komfort wybrałbym raczej Denony. Moim zdaniem fajne słuchawy bo słucha się ich z przyjemnością i...nie ma się specjalnie do czego przyczepić ;-)"
Przybyly. Swiezutkie, nowiutkie, pachnące.
Pierwsze wrazenie po wyjeciu z pudelka (pograly jaką godzine) - bardzo dobre. A u mnie pierwsze wrazenie jest decydujace :) Moze pozwolą mi wyleczyc kaca po E10 ;)
Posiadacze najwyzszych drewienek ! W1000X - nowym pogromcą top hi-endow za przyzwoite pieniadze ! ;)
Vinyloid
  • 2470 / 6038
03-06-2011, 17:03
Jezu, Max - ja jak zwykle tylko żartowałem, to jedne z najgorszych słuchawek na rynku !
Teraz też żartuję, hehe. Moje gratulacje. Btw, takie znowu tanie, to one chyba nie są ?
Max
  • 2204 / 6320
03-06-2011, 17:13
>> Vinyloid, 2011-06-03 17:03:54
Btw, takie znowu tanie, to one chyba nie są ?"
Troche wiecej niz 1/4 ceny E10... Grosze panie... ;)
Nie ma jeszcze czego gratulowac. Decyzja czy zostaną, nie zostala jeszcze podjęta. Bede walczyl w nocy.
Vinyloid
  • 2470 / 6038
03-06-2011, 17:22
W tej cenie będzie Ci trudno znaleźć coś lepszego. Uważaj abyś nie zamienił siekierki na kijek...
Max
  • 2204 / 6320
03-06-2011, 17:33
Vinyl, ja bylem gotow zostawic sobie E10, gdyby super zagraly, a kilka dni wczesniej goscily u mnie wszystkie topowe drewniaki. (Bylem wlascicielem W5000)
Tu nie chodzi o to co znajde "w tej cenie". Tu chodzi o to, ze one mi sie naprawde podobaja.
Ale dopiero wieczorem usiade do konkretnego sluchania.
alghar
  • 639 / 6535
04-06-2011, 12:18
Mam  pytanie  do kolegów  > jak długo  należy "wygrzewac " Grado PS 1000  i w jaki sposób ?
  • 4439 / 6372
04-06-2011, 20:16
Kilka postów wyżej pisałem o metodzie, którą stosuje Troels Gravesen czyli sinus 40 Hz przez 4 godziny - to jest metoda "masażu" zawieszenia głośnika, którą stosuję obecnie z każdym nowym sprzętem grającym.
GradoFan pisał wiele o wygrzewaniu grado, trwające dziesiątki jeśli nie setki godzin wygrzewanie na ogniu mały, umiarkowanym, normalnym i rozbuchanym na maxa .....
Czy w ogóle warto wygrzewać? Nie wiem, wiem, że np dźwięk AKG 271 mk II zmienił się po kilkuset godzinach na lepsze i stało się to nagle, rano grało inaczej niż wieczorem. Nie było to zjawisko na granicy percepcji a wyraźna zmiana, coś jak noc i dzień.
_______________________________
Sprzedam słuchawki Sony MDR-7509HD
  • 7477 / 6823
04-06-2011, 21:40
Grado muszą grać od najmniejszych głośności. Do tego dobrze się nadają playery mp3. Trzeba się wsłuchiwać w granicę swobodnego basu i podciągać głośność stosownie, a grać ma tuż poniżej jej. Z czasem jest ona coraz wyżej, w końcu powyżej normalnych głośności odsłuchu i ostatecznie znika. Wtedy można przejść na ostre sypanie do pieca, którego wystarczy nawet godzina. I tyle.
  • 4439 / 6372
04-06-2011, 21:43
Tak bawiłem się z wygrzewaniem Soniaczków.
  • 4439 / 6372
04-06-2011, 21:48
Max i jak tam "drewniaczki"?
Leżą jak ulał?
  • 7477 / 6823
04-06-2011, 21:49
>> asmagus, 2011-06-04 21:48:49
Leżą jak ulał?
Raczej jak uciosał. :)
  • 7477 / 6823
04-06-2011, 22:48
Miałem kilkudniową "przerwę techniczną" w odsłuchach K1000, do których wróciłem wczoraj, ale był dziś u mnie kolega...
http://forum.mp3store.pl/topic/74537-akg-k1000/page__view__findpost__p__731842
Mnie brakuje jednego odsłuchu porównawczego, który być może się odbędzie jutro, żebym przelewając wszystkie swoje myśli na temat K1000 przez klawiaturę, miał zupełnie czyste sumienie. Jak się nie uda, to będę leciał z pamięci.
  • 7477 / 6823
04-06-2011, 23:31
Odsłuch odbył się na krześle z podłokietnikami, w żadnym razie bujanym, i obserwowałem słuchającego bacznie przez cały czas. Przerywałem co chwilę luźnymi pytaniami, żeby kontrolować przytomność ciała i umysłu. Po wizycie odprowadziłem do furtki. Jak już wiem, że dotarł cały i zdrowy do domu, to dopiero jestem spokojny. :)
