  • 7477 / 6823
19-08-2010, 13:58
Moglibyście przestać pierdzielić o biżuterii i niepotrzebnych gadżetach? Mam do zakomunikowania ważną informację. Sennheiser wypuści nowe słuchawki referencyjne dla zdrowych psychicznie.
http://www.head-fi.org/forum/thread/508044/sennheiser-s-new-middle-class-to-be-announced-at-the-ifa2010#post_6865603
  • 4439 / 6372
19-08-2010, 14:04
Ciekawe jaki driver tam włożą? Ten z HD380 pro lub zupełnie nowy, nie sadze by włożyli ten nowy z HD650.
Rolandsinger
  • 2894 / 6824
19-08-2010, 14:07
To zapewne będzie quality-killer dla HD800, oczywiście prestiżem nie podskoczy, ale brzmieniowo to może być hit. Jeśli skorygują atrofię basu w HD595, a reszta nie będzie gorsza, to se do KD kupię te Senki, zamiast K701.
Śląski Festiwal Jazzowy przeniesiony na październik - kto będzie? -> Priv
  • 4439 / 6372
19-08-2010, 14:19
Ciekawe spostrzeżenia na temat HD800 vs LCD2
I did a quick review of the LCD-2 compared with the HD800 and the Stax O2.
Is it me or is the LCD-2 really really picky about amplification? On a B22, it sounded lifeless and dull. A little dark and veiled from memory. It actually came to life with a...gasp...RSA Predator. Clearer, more transparent.
Aside from sound, the biggest negative against the LCD-2 for me was the comfort (or lack thereof).
Review repeated here:
I didn\'t have more than a couple of hours with these and they were sitting in good company.
Dac was a Metric Halo ULN2.
Stax O2 out of an exstata.
HD800 out of a B22 and SPL Auditor.
First off, the LCD2 comfort level was AWFUL! It\'s stiff and clamps onto my average-sized head with such force I had to continually adjust it. I couldn\'t listen to it for more than 5 to 10 minutes. Such was the level of pain it inflicted on the side of my head.
The O2 and HD800 were spades ahead in comfort-level.
The LCD2 cable, a starquad cable (a microphone cable I believe) was stiff and just got in the way.
Sound is arguably the most important factor but in this case ultimately moot because I won\'t put use them no matter how good it sounds...I\'ll end up with a headache.
On the B22 and SPL Auditor, the LCD2 were sluggish, veiled, dark and had a recessed midrange. It just sounded terrible. I really wanted to like them.
Surprisingly, jacked into...wait for this...an RSA Predator (as a DAC and headamp), the sound signature completely changed. The veil disappeared and things were clearer. Out of a Cavelli CTH hybrid?. Similar results. Just clear.
But soundstaging was small compared with the O2 and HD800.
I would have listened more but couldn\'t bear to have them on my head. Perhaps that will change with time but for now, I\'ll pass.
Seems like these are \'flavour of the month\' on HF. Let\'s see if they have the chops to survive the long haul.
Said owner of the LCD2 (not me) has already gone on a hunt for an amp to pair with these.
Potential buyers should thus take note of two things:
1) Comfort.
2) Needs to be paired with a matching amp. Your high-end amp might disappoint. Solid state high-end amps such as the B22 and midrange-ish Auditor didn\'t do well."
Shawn_low.
aasat
  • 2434 / 6806
19-08-2010, 15:50
>> asmagus, 2010-08-19 14:19:21
Wniosek prosty, miłośnikom Grado  nowe orhto (stare tym bardziej) nie służą, co mnie nie dziwi
  • 4439 / 6372
19-08-2010, 15:51
Mój wniosek jest podobny - nie istnieją słuchawki, które zadowolą wszystkich.
  • 7477 / 6823
19-08-2010, 15:54
@Rolandsinger - atrofię basową HD595 załatwia się rezystorami.
Parokrotnie pisałem na head-fi, iż według mnie Beta22 to nie jest układ na miarę prawdziwego hi-endu, za co byłem później atakowany przez fanów tej konstrukcji, że to najlepsze co może być na tranzystorze, a że ja uważam, iż to raczej topowe produkty RudiStora mają na to większą szansę, dostawałem odpowiedź, że to hochsztapler i naciągacz, a stosowane przez niego schematy są stare i głupie jak on sam. Najciekawsze to jest, gdy za stwierdzeniami, że Beta22 to szczyt szczytów podąża kolejna myśl spod tej samej klawiatury,że słuchawki dynamiczne mają daleko z jakością do elektrostatycznych. Przy takim założeniu w sprawie wzmacniacza - nie dziwię się.
  • 4439 / 6372
19-08-2010, 15:56
Ponoć te Bety22 mają różne konfiguracje i schematów jest kilka, czytałem również, ze bardzo różnią się, jak to DIY, miedzy sobą poszczególne egzemplarze.
  • 7477 / 6823
19-08-2010, 16:01
Tys prowdo, ale ja się wypowiadam zasadniczo na temat schematu. Konfiguracja symetryczna lub niesymetryczna z wirtualną masą lub bez, więc płytek może być 2, 3 lub 4, na których jest to samo jeśli chodzi o schemat.
  • 4439 / 6372
19-08-2010, 16:03
Skoro o wzmakach mowa, jak idzie praca nad twoją "bestią" i DAC ?
  • 7477 / 6823
19-08-2010, 16:09
Na bestię mam dwa zamówienia, dałem się nakłonić. ;) Wersja tańsza i full wypas. Ta ostatnia gra u mnie na biurku nago.
ogorek
  • 855 / 6163
19-08-2010, 20:06
Odpowiadasz na wpis
>> Rafaell, 2010-08-19 12:59:36
Tu się zgodzę z przedmówcą. Zamiast odsuwać kolumny na ponad 1 m od sciany tylnej odsunąłem je "tylko" na 70 cm i przestrzeń miedzy nimi (no kawałki przestrzeni) zabudowałem słupkami (1m wysokosi) z płytami CD.
Dało to lepszy efekt (likwidacja nieliniowosci - wzbudzania na basie) niż odsuwanie kolumn. Już nawet myślałem o pułapkach basowych ale uzyskany efekt całkowicie mnie zadowola. Myślę, że takie proste próby poprawy akustyki są najtańszą możliwą alternatywą (zamiast zmian sprzętu/okablowania)
domzz
  • 1114 / 6740
19-08-2010, 21:39
>> asmagus, 2010-08-19 14:04:27
Koleżanka z pracy kupiła sobie słuchawki Tracer coś-tam za 40zł. Pady w nich są IDENTYCZNE jak te w moich HD380!
Te oryginalne do HD380 kosztują ~100zł, hehe.
  • 7477 / 6823
20-08-2010, 09:00
@domzz, ja pamiętam jak kiedyś kupiłem w kiosku zegarek za 8zł, odpiąłem z niego pasek i wyrzuciłem zegarek, a pasek założyłem do mojego Casio, bo poprzednim razem wymiana paska kosztowała mnie 25zł. Były to czasy szkoły średniej, stąd dbałość o takie kwoty. ;)
  • 6463 / 6793
20-08-2010, 11:31
Kupil juz ktos Beyerdynamic T50p :D :) ?
