Ortodynamiczny świat
intuos
  • 1003 / 6809
12-08-2009, 23:04
oto krotka recenzja LCD-1 ktore juz sa na rynku i ida po puchar :
 Default  Audeze LCD-1 just landed!
I think I\'m the first consumer to get a pair... sorry sachu!
They rushed 1 of my two pairs out in order for me to try and get it reterminated to balanced prior to the Norcal 8/8 meet. It comes in a giant ziplock bag in a functional travel bag.
They look pretty much identical to the prototypes but less beat up, a nice Audeze logo with a L on the left side (I believe designating which side is left etc and a very durable looking cable. I believe they consulted a few of our resident cable making experts for tips and used something along the lines of Canare/Belden? cable.
Did some tests immediately since I\'m still at work and it seems like it leaks as little sound as my w5000s even though its technically an open headphone with the w5000s are technically closed. It might leak slightly more on loud passages, but not enough to bother my co-worker who is sitting 3 feet behind me.
The sound? Was it as magical as I remembered at Can Jam? It\'s pretty damn impressive. Fast as all get out.I need to shoot it out carefully against the w5000/ad2000/qualias/k1000s to see where they stand.
30 minutes in and impressions start:
Interesting.. I just did a quick swap between the w5000 and the LCD-1s on Neko Case\'s "This Tornado Loves You."
I know the w5000s arent a well liked headphone, but as j4cbo can attest somehow the dynahi brings out the best from them. They sound killer with it.
Couple observations:
1. The w5000s are more sensitive. I have to go 3-4 clicks to reach ~rough level parity with the LCD-1s.
2. The w5000s seem clearer which really brings out their resolution. I\'m not sure which is more detailed at this time, but I can definitely discern where the edges of a note are better with the w5000s than the lcd-1s. This is mostly true with the mids but also as you turn up the volume on the LCD-1s they improve in this area, but do not catch up at the loudest volume I\'m willing to listen to at work ;p. Are they power starved from the dynahi? Well it is heavily attenuated after all.
3. The LCD-1 is faster it is ridiculously effortless with percussion.
4. It has better imaging/soundstage width by a good ~50% over what the w5000 has. Then again the the w5000 was never all that wide. Imaging is fantastic though. Pinpoint accurate for me in the X/Y axis.
5. Hrm another thought with regards to thought #1. Case\'s vocals sound great when it is nearly acapella... could it be that it has problems with instrument separation so when there are a lot of things going on... peripheral sounds have priority because those sound amazing.
6. They sound seem to isolate thattt well. If there\'s no music playing then I can hear my outside environment pretty well.. but I\'ve never really had a problem with isolation in general. When music is playing my attention rachets onto that and everything else fades. So I\'m not going to be a great judge at this.. sorry Dusty.
Well anyways this is all within 30 minutes over ownership so who knows how things will change or synergy will change with my other gear.
Hagusb -> Parasound DAC1500 -> Dynahi -> LCD-1/W5000
Oh looks like bass extension is pretty decent.. just heard some low bass notes on The Mae Shi - Run to Your Grave that I\'m pretty sure I haven\'t heard before.
_____________
krisio06
  • 347 / 6638
12-08-2009, 23:57
Zapowiada się bardziej niż ciekawie. :)
Tomek, czy zaywazyłeś gdzieś wzmiankę kiedy wejdą te nowe obudowy?
Ciekawe ile drewniane będą więcej kosztować. :)
intuos
  • 1003 / 6809
13-08-2009, 08:13
Zapowiada sie nawet bardzo ciekawe, acz ja osobiscie jestem bardziej ciekaw konstrukcji re5 ze strony chin, wzbudzily one najwieksze zainteresowanie i wielu tych co mialo w swoim inwentarzu omegi 007 bylo bardzo bardzo milo zaskoczonych. Wielu pisalo ze dzwiek z nich byl zywcem przeniesiony z magnetostatow do wersji nausznej, potega brzmienia i basu,szczegoly, jednym slowem bardzo bardzo ciekawe sluchawki.
LCD1 powinni popracowac nad obudowa, podejrzewam ze sama obudowa zabiera im okolo30-40% brzmienia ktora sklada sie z komfortu noszenia i estetyki obudowy.
Mam nadzieje ze nie beda kosztowac wiecej niz obecnie, bo 400$ to nie mala kwota.
intuos
  • 1003 / 6809
13-08-2009, 08:13
osobiscie nie zaplaciclbynm 400$ za cos w takiej obudowie
szwagiero
  • 2240 / 6811
13-08-2009, 09:48
Ja bym nie liczył na to, że w nowej obudowie będą kosztowały te 400$, gdyby tak było, ludzie którzy dostali je w takiej postaci jak teraz czuliby się zawiedzeni, a firma zapewne musiałaby wymieniać obudowy na nowe. Tak więc podejrzewam, że cena spokojnie podskoczy do co najmniej 500$ o ile nie więcej.
Ja również czekam na wieści o tych chińskich ortho, bo one już na starcie wyglądały lepiej, driver też wyglądał obiecująco.
Sim1
  • 1829 / 6773
13-08-2009, 11:50
Intuos, obce źródła donoszą, iż posiadasz KH-83 (73?), które są oparte o drivery z Fostexów T10. Czy to prawda? Możesz parę słów o brzmieniu napisać?
krisio06
  • 347 / 6638
13-08-2009, 14:17
O chińskich ortho ostatnio ucichło.
Tylko, że ER5, przynajmniej na cenach ogłaszanych na CanJam\'ie, mają kosztować 2x tyle co Audeze. Jeżeli tak naprawdę się stanie, to ER5 będę musiał odpuścić.
Wolałbym już poczekać na LCD1 w drewnie.
intuos
  • 1003 / 6809
13-08-2009, 14:22
Sim :)....
mialem je przez czas jakis, i niestety ale jeden z driverow padl....
faktycznie obudowa ma mozliwosc ustawiania pelnego 3d w zakresie lezenia na glowie, ale i tak uwazam ze lepsze jest samoistne dopasowywanie sie yh100.
Co do dzwieku to typowe ortho z brakiem pochlaniacza za driverem, ciemno, parno i malo emocjonalnie. Proba podrasowania dzwieku nic nie dala, w kazdym razie malo dala. Potem driver ucichl, sprawdzalem go i nic.
takze jezeli spodziewasz sie rewelacji to obudowa duzo lepiej wyglada niz reprodukcja dzwieku. Sam sie nastawialem na nowe horyzonty, dzis nie kupil bym ich.
intuos
  • 1003 / 6809
13-08-2009, 14:23
No własnie zastanawiam sie co sie dzieje z ortho er5, lcd1 w drewniw napewno otworza skrzydla, ale z tego co pamietam chinczycy uzyli kosmicznej technologii i dzwiek faktycznie wciagal niesamowicie
intuos
  • 1003 / 6809
13-08-2009, 14:25
Krisio, mam pomysl
jakby tak z dziesiec czy pietnascie osob z AH zaczelo wysylac maila do head direct pytajac sie o te sluchawki napewno szybciej brali by sie do pracy.
Cena podobno ma byc w oscylacji 600-800%, jak dolar spadnie to niszczyciel dla  oo7 omega 2 w postaci er5 bylby w drodze do Polski.. :)
intuos
  • 1003 / 6809
13-08-2009, 14:25
600-800$ :D
aasat
  • 2425 / 6792
13-08-2009, 14:27
Chińczycy to się chyba nie przejmują patentami, bo z tego co wiem, to patent ma chyba AKG i Yamaha?
Ale te firmy to chyba nigdy nie zrobią już ortho
krisio06
  • 347 / 6638
13-08-2009, 14:29
Czy da się Yh100 zmodować, tak by nie traciły swojego wypełnienia i delikatnego sopranu a zyskały w innych kwestiach?
Tomku, na Wkiphonii napisałeś, że twj mod daje YH100 dźwięk 90% z 100% tego co okazują YH1000. Czy mógłbyś to trochę bliżej zobrazować? :)
Gdzie zakupiłeś tą ruską srebrzankę i jakiego innego kabla oprócz Mogami 2354 mógłbym użyć do wymiany kabla?
Sim1
  • 1829 / 6773
13-08-2009, 14:38
>> intuos, 2009-08-13 14:22:08
[...]dzis nie kupil bym ich.
Dzięki za info, tak mnie zbierało ale widać nie ma na co :).
aasat
  • 2425 / 6792
14-08-2009, 16:53
Prawie nowe Audio-Technica ATH-2 na ebay.com
http://tinyurl.com/o5aexe
