Ortodynamiczny świat
Synthax
  • 2323 / 4980
24-10-2017, 09:04
Uboższa wersja driverów yamahy? Do tego wygląd starych radzieckich Echo TDS-16. Cena z kosmosu
Aasat dlaczego uważasz że uboższa wersja driverów?
aasat
  • 2423 / 6744
24-10-2017, 19:10
Nie do końca widać czy te nowe drivery mają pofałdowaną membranę jak w Yamaha, czy tylko cewka nałożona na membranę. Budowa przetworników Yamahy jest 3D przez co sztywność membrany jest większa niż w innych np: Fostex czy Audeze itp.
aasat
  • 2423 / 6744
24-10-2017, 19:38
Z ciekawostek, taki tekst znalazłem na stronie Yamahy.
Full drive orthodynamic headphones created through the fusion of the developers' spirit of inquiry and high manufacturing technology.
These headphones were called sensational right from their release thanks to two distinct features. One was the introduction of the "orthodynamic" full drive dynamic sounding body. This features a voice coil printed directly on the diaphragm, sandwiched in front and behind between thin perforated magnets through which sound passes, meaning that because the drive source directly becomes the sound source, divided vibration and transmission loss will in principle not occur.
This line of thought had been around for a long time, but although there were commercial products making use of the concept prior to the HP-1, none had been successful. The reason was simple. Basically, such products were difficult to manufacture, and not much benefit was found to offset the difficulty.
Looking at the HP-1 sounding body again, its diaphragm was composed of 12μ thick polyester, exactly the same as the thickness of a C90 cassette tape. That is, it could be described as an ultra-thin film. On this surface, the voice coil was densely photo-etched in a 250μ interval spiral. The voice coil was further divided into five concentric rings, the winding directions alternating for each section and the magnet likewise divided into five corresponding sections with alternating N and S poles. This meant that through a combination of the curiosity of developers and advanced manufacturing technology, this method could be successfully realized for the first time.
The other feature lies in the simple and practical form commissioned from renowned Italian industrial designer Mario Bellini. Even more than simply the beauty of its appearance, the contact of the ear pads with the ear, twin headbands sharing in supporting the entire headset on the head, and its light, airy fit thanks to a universal joint connection that allowed the ear pad section and headband to move freely must have strongly impressed the meaning of the concept of industrial design upon the audiophiles of the time.
The mid-1970's were a period of exploration seeking the next generation technology to replace the traditional round dynamic speaker. With attention in the high-end scene focused on full drive (planar) speakers, several leading makers introduced condenser (electrostatic) headphones into the market in quick succession. Considering the magnet plate as being replaced by electrodes, in operating principle the HP-1 orthodynamic headphone was very close to condenser models, an ideal method for combining the characteristics of the condenser and the ease of use of the dynamic model, no doubt serving as a demonstration of its own principles. From the catalog of the time, you can see the development team's enthusiasm to try to create something from zero that had never previously been seen anywhere in the world.
Synthax
  • 2323 / 4980
24-10-2017, 20:31
Wiesz to jest tak że duże koncerny trochę mają nas w dupie. Więc małe firmy wypełniają niszę.
To że giganci kiedyś wypuścili pewne udane konstrukcje nie oznacza, że nie da się lepiej. To tak jak z samochodami.
Nie wiem jak wypadnie ten model Final Audio. Ale im większy wybór tym lepiej dla nas. Nie ma co się zamykać na nowe wcielenia pewnych rozwiązań.
aasat
  • 2423 / 6744
25-10-2017, 13:10
Z jednej strony to pierwsza firma która wraca do pomysłu driverów a'la Yamaha po ponad 30 latach. Może inni też pójdą w tym kierunku bo na razie konkurencji brak to i cena z kosmosu (blisko $4000).
Ja się tylko zastanawiam jak to robili kiedyś Rosjanie, że w latach 80/90 potrafili skopiować takie YH-1, mowa o Elektronika TDS-5m. Zapewne były one dostępne dla przeciętnego Rosjanina.
nsk
  • 549 / 5731
25-10-2017, 16:33
Mają być jeszcze jakieś tańsze modele z tej serii więc trzeba poczekać.
aasat, cena jest taka, bo tak się dzisiaj sprzedaje drogie rzeczy, które nie mają nic wspólnego z jakością. Inni nie pójdą, bo po pierwsze nie mają możliwości produkcyjnych, a po drugie wiesz musieliby posiedzieć trochę i wydać na R&D to pomyśl jakie dopiero ceny by były ;). Final ma za słaby zasięg na Amerykę, aby to złapało zainteresowanie.
Synthax
  • 2323 / 4980
26-10-2017, 10:46
o to to
aasat
  • 2423 / 6744
30-10-2017, 08:29
Ciekawostka, obecnie najdroższe słuchawki ortodynamiczne wraz ze zmacniaczem na świecie dostępne w przedsprzedaży. Cena słuchawek 6000$, cena zestawu 18000$
Hifiman SUSVARA&EF1000
EF1000 :
Input Stage : Vacuum Tube SRPP Circuit
Headphone Output for 35Ω Load : 20w. pure Class A
Amplifier Output for 8Ω Load : 50w. pure Class A, 110w. Class A/B
SNR (A weight) : 108dB
Dynamic Range : 111dB
Weight :
Main Unit : 13.45 kg (29.65lb)
Power Supply : 11.2 kg (24.69lb)
Dimensions :
Main Unit : L460x280x170 mm3 (18.11" x 11.02" x 6.69")
Power Supply : L360x 200x170 mm3 (14.17" x 7.87" x 6.69")
SUSVARA :
Frequency Response : 6Hz-75kHz
Impedance : 60Ω
Sensitivity : 83dB
Weight : 450g (15.9oz)
« Ostatnia zmiana: 30-10-2017, 08:30 wysłana przez aasat »
nsk
  • 549 / 5731
30-10-2017, 15:36
Okleina wymiata!
Road To Nowhere
  • 1045 / 6764
30-10-2017, 19:31
Te Watty w opisie tego wzmacniacza słuchawkowego to jego moc czy "pobór mocy" ? :-)
nsk
  • 549 / 5731
30-10-2017, 20:56
 Moc. Z opisu wynika, że to wzmak do kolumn z dorobioną dziurą dla słuchawek.
Road To Nowhere
  • 1045 / 6764
30-10-2017, 21:01
Chyba ,że tak .
To mnie zmyliło:
"Headphone Output for 35Ω Load : 20w. pure Class A"
nsk
  • 549 / 5731
30-10-2017, 22:20
Dobrze zrozumiałeś, 20w z dziury słuchawkowej przy 35 Ohm.
Road To Nowhere
  • 1045 / 6764
31-10-2017, 06:59
To strach podłączyć takie np. 600 Ohm i ruszyć potencjometrem :-)
nsk
  • 549 / 5731
